en respuesta a: maxim_k
Thank you. I have the palletts back using reset palletts and have moved them where I want them.
I can't find the aws file nor do I know how to lock it. I get as far down the path as /Library/Application Support/Autodesk I do not have a "roaming" folder in the AutoDesk folder. Just an "Adim" folder and an "Adut" folder. I've tried a *.aws search with turns up nothing.
I use one monitor and do not change screen resolution.
C.S.
