maxim_k
en respuesta a: Anonymous
This is not a fatal error.
You receive it because DWG file you are trying to plot was already plotted (or has current Page Setup) with "DWG to PDF" plotter from PC version of AutoCAD. And printer (plotter) with this name is not available on your Mac. After you dismiss this alert with OK button you should be able to plot using your current OS X System printer with default paper size.
If you don't want to see this message again and again, you need to use Page Setup Manager to override "DWG to PDF" printer name with printer available on your Mac, or you can create new Page Setup with printer available on your Mac and set it current in Page Setup Manager.
BTW, if you will create new printer in Mac OS System preferences (Printers & Scanners" pane), with the name "DWG to PPDF.pc3" - yes exactly with this name only without quotes:
and set it current in Mac OS System preferences, you will not get this alert from AutoCAD when you will open DWG file that was plotted from PC version of AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
