05-11-2015
01:58 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-11-2015
01:58 PM
Welcome to Autodesk Forums!
Please check if you have Geometric constraints in your problem drawing. You can try to use menu Parametric -> Delete Constraints, than type All at the command prompt when AutoCAD will ask to select objects, than hit Return and test the drawing.
If the case is in constraints, then also check if you have Infer Constraints enabled on Status Bar and turn them off.
Maxim
Maxim Kanaev
Architect
MARSS
Maxim
Maxim Kanaev
Architect
MARSS
