293 Vistas, 1 Respuesta
uninstalling autocad 2013
Once I've opened the remove Augocad folder and hit continue so it unstalls, how long should I expect this to take? When I try to close the window, it asks me if I want to quit the uninstaller, which I don't. But it seems to be taking forever.
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Please look at this topic:
http://forums.autodesk.com/t5/autocad-for-mac-general/remove-autocad-2013-macintosh/td-p/5038302/hig...
You need to install SP3 for AutoCAD 2013 in order to be able to correctly remove it on Yosemite.
Or you can use alternative method which seems works too - install AutoCAD 2015, than remove AC 2013.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
