362 Vistas, 8 Respuestas
hatch
I use 2015 LT subscription.
I like the concept of the shading hatch and try to use it. But it doesn't seem to matter at what transparency % I use, it ALWAYS hides lines and ALL other details when I apply it. What am I doing wrong? What step am I ommiting?
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
If this happens only when you look at your drawing in the drawing window, but when you print (save PDF) it is OK, than please check "Show transparency" button on the Status Bar. It should be turned on.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
It happens when I preview and plot. I rarely plot to pdf
maxim_k
Could you attach sample file with this issue?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No, I am to busy to play. You guys are the pro's not me.
maxim_k
Please, verify that you checked "Print transparency" option in Page setup (or in Print dialog):
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
my print dialog bog box does not look like yours and the box i do have does not have print transparency as an option
maxim_k
Well, it's easy to explain - you ask in wrong Forum, because here is AutoCAD for Mac forum.
Anyway, I have found some time to find screenshot of Plot dialog from PC version of AutoCAD:
@Anonymous wrote:
... the box i do have does not have print transparency as an option
You may need to expand additional options by  by clicking the More Options button.
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
thanks that works, i am just way too busy at this time
