- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have just installed AutoCAD 2015 onto a new mac, however my PGP file does not seem to be loading.
All the paths, within options are correct and the pgp file was carried straight over from my old mac. Are there other locations it looks for the pgp file, and if so does anyone know how to fix this to force it to reference the correct pgp file?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi John,
Where did you put your custom PGP file?
The default one is in "~/Library/Application Support/Autodesk/roaming/AutoCAD 2015/R20.0/enu/Support" folder, as usual.
If you want your custom PGP file to be loaded instead of the default, you need to put it to the folder which is on the top of "Support files search path" list in Application tab of AutoCAD:
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks Maxim,
I think it must have been how our IT guy created an image of part of my previous mac, prior to installing the software. The pgp file was not loading anything (even the default stuff). I've therefore uninstalled, and reinstalled everything from scratch including my personalised settings. Everything in regards to cutomisation now appears to be working.
John.
