maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Geg,
You need to verify that all layers are turned on and not frozen in the drawing - dimensions could be on the layer that is turned off or frozen.
You can also check Paper space, maybe your client put dimensions dimensions in the Layout.
if you want, you may attach the drawing here, I can look at it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
