en respuesta a: pendean
Tried lots of Google searches but to no avail. First question on the google blocks (I assume you mean 3D objects when you say this), is how do I import them into AutoCAD? When I import the wire frames nothing happens, the work seems to be compelte but the objects are not there.
Secondly I have had a look at tapering tubes to be able to get branch like formations. The way I go about this is :
1) Create a curve line
2) Create a circle
3) Sweep the circle onto the line
4) modify -> solid editing -> taper
5) Select Faces by clicking on the new tube (all faces select). Press enter to accept selection.
6) Specify base point: I click on the centre of the one side of the tube.
7) Specify another point along the axis of tapering: Not sure what this is supposed to be but clicking on the centre of the tube
8) Specifiy the tape angle: Needs to be between -90 and 90. Eneter a random number
Modeling Operation Error:
could not taper surface as requested
What am I doing wrong? Dammit just want to make a branch :cara_con_una_leve_sonrisa:
