2202 Vistas, 8 Respuestas
Creating organic shapes like 3D trees & branches
Is this the correct forum to be posting questions around how to design in Autocad or where should I be posting?
pendean
en respuesta a: Anonymous
If you are using the MAC version, this is the correct forum.
AutoCAD is not the best choice to create organic shapes like trees and branches: but there are many 'free' and not-so-free blocks and libraries already created that you might benefit from, try a google search for these.
en respuesta a: pendean
Tried lots of Google searches but to no avail. First question on the google blocks (I assume you mean 3D objects when you say this), is how do I import them into AutoCAD? When I import the wire frames nothing happens, the work seems to be compelte but the objects are not there.
Secondly I have had a look at tapering tubes to be able to get branch like formations. The way I go about this is :
1) Create a curve line
2) Create a circle
3) Sweep the circle onto the line
4) modify -> solid editing -> taper
5) Select Faces by clicking on the new tube (all faces select). Press enter to accept selection.
6) Specify base point: I click on the centre of the one side of the tube.
7) Specify another point along the axis of tapering: Not sure what this is supposed to be but clicking on the centre of the tube
8) Specifiy the tape angle: Needs to be between -90 and 90. Eneter a random number
Modeling Operation Error:
could not taper surface as requested
What am I doing wrong? Dammit just want to make a branch :cara_con_una_leve_sonrisa:
maxim_k
I think in your case it is better to use LOFT command:
- create spline (or polyline) to use it as a path for loft
- create two circles on the end points of the path - align them perpendicular to the path at this points,
- start LOFT command and select first and second circle, than hit Return two times and select "path" option,
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
I attached sample loft object, which I created. Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
That is perfect! I have my first branch.
What would be the best way to smooth the objects into each other as the edges are rather rough?
maxim_k
You can try to convert 3D Solids to Mesh objects with MESHSMOOTHMORE command and apply different smooth levels.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thank you so much Maxim_k, your example rocks! You have taken what I was trying to do to the next level!
nick.ollila
Hi Maxim,
How did you align the circles so that they were perpendicular to the path at the end points?
Nick
