maxim_k
en respuesta a: mzarchs
After changing MEASUREMENT system variable you need to reopen the drawing.
When I tested your pattern, I added it to the end of acadlt.pat file:
*ZIGZAG, Staircase effect
0, 0,0, .125,.125, .125,-.125
90, .125,0, .125,.125, .125,-.125
;; User Defined Hatch Patterns
;; Add any hatch patterns that you define to this section of
;; the file to ensure that they migrate properly when
;; upgrading to a future AutoCAD version. If duplicate hatch
;; patterns are found in this file, items in the User Defined
;; Hatch Patterns section take precedence over patterns that
;; appear earlier in the file.
;; <- Begin mzamasonry ->
;; MZA masonry elevation
*mzamasonry, MZA masonry
0, 0,0, 0,8
;; <-End mzamasonry ->
What if you will create new drawing from acadlt.dwt template? Can you see your pattern in it?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
