03-31-2015
08:44 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-31-2015
08:44 AM
Welcome to the Autodesk Forums!
Hi André,
I think you need to try the solution from this topic:
You need to replace "AutoCAD LT" to "AutoCAD 2015" in application name and the path to support files I mentioned in that solution: from "~/Library/Application Support/Autodesk/roaming/AutoCAD LT 2013/R19.0/enu/Support" to
"~/Library/Application Support/Autodesk/roaming/AutoCAD 2015/R20.0/enu/Support"
You can also look at this discussion:
Maxim
Maxim Kanaev
Architect
MARSS
