en respuesta a: maxim_k
That did not work for me unfortunately.  I went ahead and uninstalled and reinstalled.  That did the trick.
As a side note for anyone else with similar issue, when I reinstalled, the installer would not move forward until I killed the remaining AutoCAD 360 application that did not get removed during the unistall.  I had to go into the activity monitor, scroll through the activities till I found the AUTOCAD360, highlight it then delete it.  Then you can get the re-install to move forward.  Sounds simple, but took me quite a bit of time searching as I am not an APPLE MAC wiz-kid ;-)>
Thank you.
