- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Welcome to the Autodesk Forums!
Hi Lisa,
1/ Ribbon is not available in AutoCAD for Mac
2/ You need to clear check mark "Use Shift key to add selection" in the "Cursor & Selection" tab of AutoCAD Preferences window (menu "AutoCAD LT 2015" -> Preferences
3/ You can accomplish this the same way as in PC version. Clear all running object snaps on the "Object Snaps" tab of AutoCAD "Drafting Settings" window (menu Tools -> "Drafting Settings"). than choose one of the following methods:
- use keyboard shortcuts NEA, END, MID, etc. when AutoCAD asks you to pick point
- use right click context menu "Snap overrides" which is available inside most of drafting/editing commands
- use OSNAP context menu inside drafting/editing command - you can activate it with Shift+right click or with middle click (if the system variable MBUTTONPAN=0)
- create custom buttons for object snaps on Tool Sets palette and use them when you need
4/ About manual - I think you can try this:
http://www.infiniteskills.com/training/learning-autodesk-autocad-lt-2015-for-mac.html
Maxim
Maxim Kanaev
Architect
MARSS
