594 Vistas, 6 Respuestas
AutoCAd Lt 2015
I just switched from AutoCad Lt 2009 for PC to AutoCad Lt for Mac and having a lot of trouble -
can you get the ribbon format?
when i select more than one item - do i always have to hold the shift key - is there a way to change that?
i like to keep the snaps off and then use them for each line - can i do that ? like start a line from a midpoint and go to a perpendicular point ?
is there a good manual?
maxim_k
en respuesta a: Anonymous
Welcome to the Autodesk Forums!
Hi Lisa,
1/ Ribbon is not available in AutoCAD for Mac
2/ You need to clear check mark "Use Shift key to add selection" in the "Cursor & Selection" tab of AutoCAD Preferences window (menu "AutoCAD LT 2015" -> Preferences
3/ You can accomplish this the same way as in PC version. Clear all running object snaps on the "Object Snaps" tab of AutoCAD "Drafting Settings" window (menu Tools -> "Drafting Settings"). than choose one of the following methods:
   - use keyboard shortcuts NEA, END, MID, etc. when AutoCAD asks you to pick point
   - use right click context menu "Snap overrides" which is available inside most of drafting/editing commands
   - use OSNAP context menu inside drafting/editing command - you can activate it with Shift+right click or with middle click (if the system variable MBUTTONPAN=0)
   - create custom buttons for object snaps on Tool Sets palette and use them when you need
4/ About manual - I think you can try this:
http://www.infiniteskills.com/training/learning-autodesk-autocad-lt-2015-for-mac.html
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Thanks!
Sent from my iPhone
Why does "save as" only offer choices of old formats... isn't there a file type for 2015?
maxim_k
AutoCAD 2015 and new AutoCAD 2016 which is available now on PC both use 2013 DWG format. There is no newer than 2013 DWG format.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
When using a command such as "stretch" and you are selecting objects - how do you get your window to be in ortho mode - a rectangle - as opposed to a random shaped bubble?
maxim_k
When you start to make selection you just need to pick two points- at the he first an at the second corner, you don't need to drag mouse with pick button pressed.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
