03-22-2015
12:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-22-2015
12:37 AM
Thanks for the quick reply, i have cometley removed AutoCAD went through and moved unistalled items to trash incase i need them later, and then installed a fresh copy i was then able to reach the activation page where you in put the activation code did that, then it requested login detail to Autodesk which you cannot bypass and then thereaftew you are presented with the autodesk licence server is offline etc screeen which i included above. Tired those terminal comands in the post that you mentioned but they do not appear to have worked. I have lodged a request with the subscription side awaiting a repsonse they intially came back with an activation code only.
Do you feel it is a Mac issue or CAD issue
Cheers
Chris
