414 Vistas, 7 Respuestas
printing with mac Page size problemes
I need the help of the community for a weird problem
Since I use AutoCAD for mac I can't print my documents directly from AutoCAD to my plotter. Both letter and 11x17 work fine
All my page setup is set to a a1 format when I check the preview the page show correctly, but when I print it always print only to a letter format
Although if I just print from the preview or from the pdf it all work fine.
What's weird is that on five different computers we are two persons that have this problem
We tried reinstalling the printers, but it didn't change anything.
Someone is already experienced that ?
maxim_k
en respuesta a: Anonymous
Have you tried to create named page setup in Page Setup Manager, set it current and than use Print command to print to your physical device?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
I tried
But it didn't change the situation
In autocad for windows isn'it a place in the options for printer setup but  not in mac ??
Tank you !
maxim_k
Which printer do you have?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
HP Designjet T520
but like i said  it works on other exact same computer.
That is why i think its an option in autocad , but i am no expert !
maxim_k
Do you use A1 format from the predefined paper sizes? Or you use custom A1 paper size?
If you use A1 from the list of predefined paper sizes, than try to create custom paper size of A1, give it some specific name , for example "A1 Custom", than use it in Page Setup and try to print.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I did exactly that , but it didn't resolve the probleme.
I will atempt to see whats the diference between one computer to another.
Maybe the answer is there. but is there a plotter manager in the mac version ?
maxim_k
If you mean AutoCAD Plotter Manager (like in PC version) - no, there is no such feature in Mac version.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
