1317 Vistas, 5 Respuestas
03-14-2015
06:19 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-14-2015
06:19 PM
Ghost lines appear in extruded geometry
After drawing lines/arcs, joining and then extruding, phantom lines appear in the geometry in Model space.
They shift/disappear/reappear sporadically as I pan and zoom. Seems to only effect shallow extrusions (1/4" lauan material).
Any way to fix this?
GhostLines.tiff
22 KB
03-15-2015
01:22 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
03-15-2015
01:22 AM
I cannot reproduce this issue on my side with any Visual Style. Can you attach your drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
Maxim
Maxim Kanaev
Architect
MARSS
06-11-2015
10:57 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-11-2015
10:57 AM
I have the same problem except it is in paper space. Phantom lines will appear on objects, usually connecting with something like a hole in the solid object. If I zoom in close they go away. But when I print the layout the lines print as well. I have attached a page where this appears. It is in an isometric view of a round flat lid. Any help would be appreicated.
PHANTOM LINE EXAMPLE.pdf
263 KB
06-11-2015
11:57 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-11-2015
11:57 AM
Welcome to Autodesk Forums!
Could you attach DWG file with his issue?
Maxim
Maxim Kanaev
Architect
MARSS
Maxim
Maxim Kanaev
Architect
MARSS
06-12-2015
09:46 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-12-2015
09:46 AM
Here is the cad from which that layout came from...you can see lots of examples of the issure in here. Thanks
sample cad.dwg
3062 KB
06-13-2015
07:27 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
06-13-2015
07:27 AM
I can reproduce the issue on my side.
After quick investigation I can say that this issue could be a bug in AutoCAD (in both versions - for Mac and for PC): these lines appears in viewport with visual style other than 2D Wireframe when 3D Solids are extremely thin in compare to its area.
Look here:
http://forums.autodesk.com/t5/autocad-2007-2008-2009/quot-ghost-quot-lines-on-thin-3d-solids/td-p/19...
You can try to use SOLPROF workaround or create flatten view of 3D objects with FLATSHOT command, than put the result to Layout.
Maxim
Maxim Kanaev
Architect
MARSS
Look here:
Maxim
Maxim Kanaev
Architect
MARSS
