maxim_k
en respuesta a: Anonymous
You can try another workflow (I tested it in 2015 version):
- open project which Layouts are missing (you move DWG file to another location on disk)
- you should receive warning from AutoCAD:
- pick on the second option "Select a new drawing..."
- now the new window should open "Repair broken layouts":
where you can add new (actually old, but from another location) drawing with "+" at the bottom, than for each of the Layouts select this drawing in the 3-rd column of this "Repair" window, than select corresponding layouts in the 4-th column to match the names in the first column.
- click on OK and all Layouts should appear in the Project Manager window.
And yes - in order to be able to use Project Manager - for example to open project - you need to have drawing opened in AutoCAD, this could be even new empty drawing, not related to the current Project.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
