Victoria.Studley
en respuesta a: Anonymous
Hi Jason,
I'm glad to hear you were able to find a way to accomplish this. It also looks like most of the objects in your drawing are on the 0 layer. You could reduce the complexity around intersections like this by placing objects on separate layers, to be toggled on and off as needed. You could also use QSELECT to select a filtered set of objects and isolate them to make them easier to work with.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
