- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
My blocks don't line up.
Using LT 2015 with 10.10.2 (actually 10.10.3 Beta, but this has been happening since long before this beta)
Outside of the block editor, if I create a box and then duplicate that box (Apple+C , Apple+V) and select a grip on one of the boxes, I can drag it and connect it to an end point on the original box and it lines up perfectly. I verified this by zooming in some insane amount (I can't never actually tell what the current zoom level is. Is there a thing for that?):
I have a block. Within that block there is another block of a box. If I do the same thing, duplicate the block of a box inside the other block (this is starting to sound like a Dr. Seuss poem!) using copy/paste and try to line them up, they just won't do it:
I've even gone ahead to make sure that the the top-left side of the box block is 0,0,0:
I just don't get what I'm doing wrong here. It's wreaking havoc on my drawing because I expect the copy/paste/move grip to connect to an endpoint and align itself perfectly no matter if I'm drawing a box or using a block.
Thanks in advance!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think you need to revise all your blocks, for example I noticed that in one of the blocks inside your drawing; FM - F1AS9N-1A12-10S, there are another blocks which seems lined up, but if I zoom deep enough to the object corners in this block (I explore this block in Block Editor), I can see this:
the objects doesn't lined up correctly.
So it is possible that when you use END object snap you accrue wrong endpoint inside your blocks - this gives an error in aligning blocks.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes, I'm starting to realize that my entire drawing needs to be re-done. I incorrectly assumed that the snapping was accurate, but it seems that's not the case at all.
Is there any way to make snapping idiot-proof or does it usually always require zooming in to the nth degree?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
At the same time for ENDpoint object snap sometimes it is enough to position cursor over the line and wait for a half of second autosnap marker to appear at right endpoint of the line, than you can just click with mouse button and you will get right snap- it is not necessary to move cursor toward the endpoint.
Maxim
Maxim Kanaev
Architect
MARSS
