1004 Vistas, 7 Respuestas
AutoCAD LT 2015 MAC : OS X 10.10.2 : Hangs on quit
I've been having an issue for some time where upon quitting, AutoCAD will just hang, it will never actually quit.  This requires that I force-quit the application.  It doesn't matter if I save+close all open drawings first or not.  It doesn't seem to do it all the time. It seems to do it after AutoCAD has been running for some time.  I run it on a laptop, so the machine is put to sleep and woken up again duriong transportation; perhaps that is a contributer?
I checked to see if there were any updates, but I'm apparently up todate.  I have recently tried to reset AutoCAD and enable OpenGL.  The latter of which seems to have resolved a high CPU issue I was having as well, so that's a good thing, I guess.
I have a Mid-2014 MBPR Retina | 2.8Ghz i7 | 16GB | NVIDIA GeForce GT 750M 2048 MB
Forum searching doesn't have anything specific to my case; they all seem to be inssues starting up, not shutting down.
Any ideas?
Maybe someone from Autodesk is listening?
Thanks!
pendean
en respuesta a: Anonymous
PC going to sleep/Autocad freezing up afterwards is probably a sign you either need to extend the sleep time to not affect you or get in the habit of restarting Autocad more often in your workday.
maxim_k
Hi Jason,
If you have rental AutoCAD license, than it is known issue, which was discussed here:
http://forums.autodesk.com/t5/autocad-for-mac-general/autocad-lt-for-mac/td-p/5381355
The workaround for now is to create new drawing before you want to quit AutoCAD, than quit application.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: pendean
Hi pendean,
To clarify - my laptop only goes to sleep when I close the lid to transport it.
en respuesta a: maxim_k
Hi Maxim,
Thanks for the link. I don't know why my search-fu failed me. I couldn't find anything relating to hanging issues on shutdown before I posted here...
In any event, I tried the suggested workaround, but it was ineffective. I did gather a sample and I will send it to Wei.
maxim_k
OK, I am sure they are working to solve this proble.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
here it is 6 months later...
I am using autocad lt desktop subscription for mac. Every single time I am done using autocad and choose quit the program just hangs there and to stop it it always needs to be force quited.
I hope they fix this since it seems to have been a bug for a while now...
maxim_k
Welcome to the Autodesk Forums!
It is already solved on Jul 28:
AutoCAD LT 2015 for Mac Update 3
Jul 28 2015  |  Download
Applies to AutoCAD LT for Mac 2015
The Update 3 specifically resolves the issue that AutoCAD LT 2015 for Mac sometimes hangs at quit. The Update 3 is a combo update which also includes the fixes in Update 1 and Update 2. It can be patched directly over the original version, the Update 1 version or the Update 2 version of AutoCAD LT 2015 for Mac.
AutoCADLT2015Update3_English.dmg (dmg - 120.79Mb)
AutoCADLT2015Update3_French.dmg (dmg - 134.86Mb)
Readme
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
