- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
dashed lines in plan in model space show as solid in paper space. picked dashed line for object; picked dashed line for that layer; tried everything and just lost work because of it. I hope I have to search and set a hundred line scales in various places to "1" then coordinate several layer items and model space and paper space issues because a 2d drafting program should not be simple! I forget this is "robust" program haha ![]()
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Try to use LINETYPE command to open Linetype Manager dialog (Menu: Format ➤ Linetype) and while you are in Layout uncheck "Use Paper Space Units for Scaling". Close dialog to save changes, use REGENALL command to regenerate all viewport.
You need to repeat steps above for all Layouts in the drawing.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Unfortunately there is no special reference manual for AutoCAD LT 2015 for Mac, but for general reference you can use any of the manuals about AutoCAD LT (PC version) keeping in mind differences between PC and Mac versions:
http://www.autodesk.com/products/autocad-lt/compare/compare-platforms
You can also try this video course:
http://www.infiniteskills.com/training/learning-autodesk-autocad-lt-2015-for-mac.html
Maxim
Maxim Kanaev
Architect
MARSS
