maxim_k
en respuesta a: Anonymous
@Anonymous wrote:
It´s maybe a problem due to a lack of memory.
Yes, probably.
@Anonymous wrote:
The file I´m working with was generated from a 3D Software (Rhino) ..
I also noticed in some case if you have 3D objects in your drawing (or objects with thickness greater than 0), the "highlight issue" could appear from time to time. You can look at your drawing from other point of view - use 3DORBIT command to check "flatness" of the drawing.
You can also look at this topic:
http://forums.autodesk.com/t5/autocad-for-mac-general/highlighting-in-dash/m-p/5355501#M13156
(my short screencast about 3D objects is on the last page of this topic)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
