maxim_k
en respuesta a: suzidavis
Hi Suzi,
About your first question - yes such scenario could work, you can also look at this:
http://forums.autodesk.com/t5/autocad-for-mac-general/help-new-mac-autocad-15-no-printer-and-can-t-g...
About the issue with CTB file from Windows: which output size is on Windows side? Is it the same as you tested on Mac (11 x 8.5 paper)? Or it is bigger?
Could you attach here example DWG file with accomplishing CTB file? (it is better to compress them in one archive before attaching).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
