en respuesta a: maxim_k
I use the measure icon. Using the DIST and AREA commands, when I've selected the second/final point, there is no distane or area, the cursor acts as though the command is complete. MEASUREGEOM gives the same result as using the icon and asks for what type of measurement after I've selected the second point.
The issue of selecting a block to insert went away a couple of times after hanging for aseveral minutes when trying to select the folder containing the block, but now it freezes the screen and I have to force quit before I can use any other program, even those that are open and on screen.
These two problems have only begun since the system upgraded to 10.10.2, it was fine up till that point.  In order to work on a drawing I have to use an older machine running Autocan 2011 on 10.6.8.  Not the ideal solution and, until I can find a solution to this problem, a complete waste of money upgrading to 2015.
