437 Vistas, 2 Respuestas
Delete command
Can anyone help with what (I hope) is a simple fix ?
When I want to delete something (or move or copy) I click on it, but when I want to delete (or move or copy) multiple things when I click on a second item the first one 'unclicks' itself.
How do you configure the set-up to allow the addition of more than one item to be deleted (or moved or copied) ?
Can anyomne help ?
Andy
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Andy,
Please check PICKADD system variable - it should be = 2, probably you have 0.
You can also change settings in AutoCAD Preferences -> Cursor and selection section -> Un-check "Use Shift key to add selection"
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Perfect - this is so very helpful !
Thank you
