- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
CAD freezes when I select an inserted block
Hi All,
Autocad 2015 has been working great until I insert a block, I use the command "insert" then select the file, and then the attribute dialog box comes up and I click insert. I can view the inserted block, and click an insertion point, but when I try to highlight the inserted block Autocad freezes and I have to force quit. I have tried to insert it at 0,0,0 so I dont have to select an insertion point, I have also tried to purge and audit the data I am trying to insert.
This has happened with serveral files I have tried fo insert, and I am wondering if the attribute dialog box has anything to do with something?
DS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Welcome to Autodesk Forums!
Could you post (attach) here the file you are trying to insert? It is difficult to say something without having it at hand.
Maxim
Maxim Kanaev
Architect
MARSS
