2220 Vistas, 3 Respuestas
view cube missing
I'm recently switched to AutoCAD LT 2015 for Mac (from an older PC version) and I can't locate the view cube anywhere. Per the product info, I should be able to go to"view," "display," "viewcube" but it just doesn't exist in my drop down menu (see attached image).  Nor can I conjur it through commands "navvcube" or "viewcube"...it responds "unknown command."  Any thoughts why it might be missing, and/or how I can get to appear?  I use it frequently, would love to have it....
Etiquetas (1)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
The ViewCobe is not a feature in AutoCAD LT! And never was a feature. The information in product info you are referring to is WRONG!
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
http://knowledge.autodesk.com/support/autocad-lt-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2015...
the above is incorrect? ....it looks so official.
Thank you for the heads up.
maxim_k
Here is more correct information:
http://www.autodesk.com/products/autocad-lt/compare/compare-products
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
