3403 Vistas, 3 Respuestas
Change comma to period
Hello!
I have installed the student version of AutoCAD on my new MacbookPro. As I am working with a Belgian AZERTY keyboard, I already changed my settings for decimals to the following:
Separating numbers:
- groups: space
- decimals: ,
Valuta:
- groups: space
- decimals: ,
With this i can work with the comma button ("," in between the "0" and the "Enter" on my external keypad) for numeric values (eg "one and a half" is "1,5") properly in Numbers and the calculator.
BUT only AutoCAD doesn't accept these settings. When I want to draw a line of one meter and a half, I would like to type "1,5" but instead AutoCAD reads this as X=1 and Y=5, which results in an angled line with a different length.
I would like to know how I can change this, because I would like to use "," on this keyboard as an actual decimal comma without needing to switch to my fixed keyboard and holding the shift key to type a dot ".".
Any advice is welcome!
Charlotte
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
It is impossible in AutoCAD, as it is "hardwired" at the program level:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=854
You can only adjust settings for dimension style, but not in command line.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
it is possible:
System Preferences- Language and Region- at the bottom of the box click "Advanced"- then choose the dot/ comma under Number separators- Decimal and again under drop down box "decimal" under currency
maxim_k
You can do this on OS level and some applications will use these settings (for example - MS Word, MS Excel), but not AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
