420 Vistas, 4 Respuestas
pdf
I cannot find the DWG to PDF in the plot folder. All help topics say it is the default printer. How can i install it. I want to save as ISO A1 pdf so i can send out.
I am using Autocad 2015 on a macbook pro
h_s_walker
en respuesta a: Anonymous
Welcome to the Forums
Unfortunately this is Autocad for Windows, you need AutoCAD for Mac
BUT Before you go. Choose PUBLISH. There is an option in there under PUBLISH TO where you can select PDF
Howard Walker
Left Handed and Proud
filipefrancisco
you have to install an PDF printer on the MAC to solve that problem
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
pendean
1. you are in the wrong forum http://forums.autodesk.com/t5/autocad-for-mac/ct-p/3011
2. MAC PDF output is done through the OS, it's built in. Nothing for you to install.
maxim_k
Dean is absolutely right: PDF output is built in Mac OS. You only need to create Custom paper size if your System printer doesn't support A1 paper size:
http://www.cadtutor.net/forum/showthread.php?55873-Quick-Tutorial-Plotting-Custom-Paper-Sizes-in-Aut...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
