528 Vistas, 2 Respuestas
Double click on text
When I double click on a piece of text it brings up the _ddedit command, but as this is now discontinued in 2015 it displays the message 'unknown command'.
Is there a way I can modify this to change the command that is actioned when double clicking on text to textedit?
maxim_k
en respuesta a: Anonymous
Hi John,
I cannot reproduce this issue.
Please open CUI editor and check macros assigned to "Text, edit..." and "Mtext, edit..." commands, they should be:
Check also have you by chance edited (substituted) DoubleClickRoot.cui file, which is inside AutoCAD application.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Hi Maxim,
My cui had the text, Edit.. command linked to ddedit, so I have changed this, and after a reboot it seems to now work fine again.
I did a search for the doubleclickroot.cui and although this has not been changed by myself I did note that there are still a number of references to ddedit still remaining in it.
Kind regards,
John
