maxim_k
en respuesta a: Anonymous
@Anonymous wrote:
When you say Autocad creates a new drawing do you mean it actualy creates a new file so edits in one no longer reflect in the other?
If you add Layout to the Project by using "New layout" from the context menu (right-click on Project name):
Yes, AutoCAD creates new drawing based on the template you specify in this dialog:
@Anonymous wrote:
...I am not clear about is why I can open layouts from Project manager for some projects but not others, its as though the connection between projects and drawings has different degrees.
You can not open Layouts from the drawings in the Project when:
- layout was created in the drawing attached to the Project AFTER you attached this drawing to the Project
- layout in the drawing attached to the Project was not initialized at the moment when you added it to the Project. Initializing means that you need to open the layout in the drawing at least one time.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
