maxim_k
en respuesta a: Anonymous
@Anonymous wrote:
Am I correct that if I add a layout using the right click menu there is no way to get it into the project?
No this is not correct - as soon as you add Layout in Project Manager AutoCAD creates new drawing for you with Layout you asked and adds it to the current Project.
@Anonymous wrote:
Is it possible for a drawing to be only partialy attached to a project?
AutoCAD will add all layouts from the drawing (if you select "Add Layout from the drawing"), you can not select which Layout to add as in Windows version. Later you can remove unnecessary layout(s) from the Project.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
