maxim_k
en respuesta a: Anonymous
Unfortunately you can not add single Layout from the drawing (no matter whether it is already in the current Project or not). It is limitation of Project manager feature in AutoCAD for Mac.
In AC for Mac you can only add ALL Layouts from the drawing via project Manager. So only one way to add Layout you created in the drawing is to use right-click context menu on the Project name in Project Manager,, select "Add Layout from Drawing", than choose your drawing and confirm duplicate and add option:
Than you need to delete Layouts you don't need in the Project (those that come from duplicate DWG file).
The drawback of this workaround is that you need to duplicate your DWG file and use it as additional file in the project.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
