2125 Vistas, 9 Respuestas
Project and layuout properties in blocks
I am trying to make a block that will show custom properties of the project and layout when it is droped onto a layout.  There is a cryptic page in the manual:
About Sheet Label Blocks and Callout Blocks
which suggests this should be possible.  It says this is done with attributes but is not clear how.  A button next to Default on the attribute definition page brings up the insert field menu but the custom properties are not visible in this environment.  The instructions mention placeholders,  There is an item ProjectPlaceholder and inside this type can be custom but under that it asks for a name which is blank.  Entering the name of a custom property here has no effect. (I get the name not the property value when it displays)
Is there some guide to this for the MAC version
 I have attached the insert field window I think is the place I should be using.
