818 Vistas, 1 Respuesta
AutoCAD 2013 SP3 Cannot Install on Yosemite
I cannot install SP3 as I need to install SP2 first, but I cannot install SP2 as I get the following error message running the latest version of Yosemite:
SP2 install error message
"This version for AutoCAD 2013 for Mac requres OS X 10.6.4 or later".
I also cannot use the Remove AutoCAD 2013 app because it does not run correctly on Yosemite, so I can't reinstall AutoCAD 2013 either.
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
I believe the fix shold come from Autodesk side, but for now you can try the solution I posted here (see message #5):
http://forums.autodesk.com/t5/autocad-for-mac-general/autocad-lt-2013-yosemite-trouble-re-install/td...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
