en respuesta a:
09:49 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-27-2014
09:49 AM
More on using the contents of a text object as a field:
Strange behavior on using the contents of a single line text object as a field in another text object. I have two text objects which both have a field that uses the content of another text object. These two objects are on different layouts. If I change the content of the source text object the fields on other layouts update immediatly but a field on the same layout only updates if I issue the FIELDUPDATE command or leave the layout and return. Apparently displaying a layout causes all fields to update.
