cheryl.buck
Hi @Anonymous,
Thank you for the update, I am glad you are not seeing the issue on the new computer. If you are still seeing it on the previous one, it may be a corrupted user profile.
You can test this by resetting to defaults, see the Autodesk Knowledge Network (AKN) article How to reset AutoCAD to defaults. You will get the opportunity to export a copy of your current settings prior to the reset. If this resolves the issue, you can test to see if the issue returns if you reimport your settings.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
