basnederveen
8020 Views, 12 Replies
VBA Printing to PDF
Hello everyone,
I can't manage to set any print configurations, everytime I open a drawing it resets to what is default in the drawing. The problem occurs with some drawings exported from another program (cadmatic... ) and trying to print to PDF.
---- edit  -----
Now I am loading a few preset plot configurations from another drawing, which seems to be working. Only I would like to use the button 'Apply to layout'. Does anyone know if this is possible thourhg VBA?
Function DoPdf(dwg As AcadDocument, pdfFile As String, config As String) As Boolean
    ' Initialize the acad plot, configs and configurations
    Dim ptObj As AcadPlot
    Dim ptConfigs As AcadPlotConfigurations
    Dim plotConfig As AcadPlotConfiguration
    ' Create a new plot configuration with all needed parameters
    Set ptObj = dwg.Plot
    Set ptConfigs = dwg.PlotConfigurations
    ' Add a plotconfiguration
    ThisDrawing.SendCommand "filedia" & vbCr & "0" & vbCr
    ThisDrawing.SendCommand ".-psetupin" & vbCr & "PATH" & vbCr & "*" & vbCr & vbCr & vbCr
    ThisDrawing.SendCommand "filedia" & vbCr & "1" & vbCr
    ' Set the configuration
    Select Case config
        Case "a3"
            Set plotConfig = ptConfigs.Item("Spools_a3")
        Case "a2"
            Set plotConfig = ptConfigs.Item("Spools_a2")
        Case "a1"
            Set plotConfig = ptConfigs.Item("Spools_a1")
    End Select
    ' Set background plotting to off so autocad will wait till print is finished. Prevents errors.
    Call ThisDrawing.SetVariable("BACKGROUNDPLOT", 0)
    ' Updates the plot
    plotConfig.RefreshPlotDeviceInfo
    ' Create a variable to see if print was succesfull
    Dim success As Boolean
    ' Catch the error
    On Error Resume Next
        success = ptObj.PlotToFile(pdfFile, plotConfig.ConfigName)
    If Err Then
        'MsgBox "Not printed"
    End If
    ' Delete the previous config
    Set plotConfig = Nothing
    ' Return the result
    DoPdf = success
End Function
