fm22BA6RM
373 Views, 1 Reply
Región clasificada- Graded region
I have a problem in my revit model that I don't know how to solve. I made a toposurface in the "existing" phase, then I made several building pads in a new phase called "desmonte", after that I used the tool Graded Region using the toposurface of the "existing phase. This tool gave me two options: Copy the same as existing or Copy using just boundaries.
In this stage, when I click any of the two options, is when the error is produced. A warning is showed: "Se ha producido un error inesperado en Revit. La operación se ha cancelado para evitar que se dañe el proyecto.", referring to the element "(Elemento suprimido ) : ID = 240260"
Actually I modified the phases mechanism. I moved everything, the toposurface and the building pads, to the "new construction" phase, but Revit still returning the same error.
The error export is:
Informe de errores de Casa Raumplan 02 (01/08/2017 0:31:44)
Mensaje de error
Elementos
Se ha producido un error inesperado en Revit. La operación se ha cancelado para evitar que se dañe el proyecto. : (Elemento suprimido ) : ID = 240260
The Revit file which I gave me this error is attached.
Thanks in advance.
