- Mute
- Permalink
- Report
Recuperación del cuadro de dialogo en edición de nivel en Revit
Buenos dias
He seleccionado la opcion de no mostrar de nuevo el cuadro de dialogo en la edicion de cambio de nombre de nivel (en plano) y ahora deseo recuperar muestre de nuevo el cuadro de dialogo, ahora no lo hace ni cerrando y abriendo de nuevo el programa, ni reiniciando, por favor ayuda!...
Muchas Gracias
Victor Rodriguez
@rodriguezmarmol para una mayor claridad @joaquim.moral ha editado el título original: Recuperación del cuadro de dialogo en edición de nivel. Consulta cómo escoger el mejor título para tu post. ¡Gracias por participar!
- Mute
- Permalink
- Report
Is this the item you are trying to bring back?
Selecting the Level should show the blue Box but if not try changing the Level Type to another Style and also check the Edit Type Settings to see if the Symbols are turned of in the Family itself
Autodesk Certified Instructor
- Mute
- Permalink
- Report
Hello Jay
Thanks so much for your quickly reply!
but sorry, is about this:
when you have a level, any
______________________________Level 1
3000 m
like this for example, and to modify the name of level (for example), just double click in the name and edit the name
after you edit, a windows pop up telling: if you dont want this message again just click in the box
(i did it, I clicked in the box)
and now, afyer that, whenever Im in REVIT, never more show the windows,
Including restarting the revit, closing and opening again, new project, etc etc, never more the wondows pop up
I would like to have it again.
Am I clear with the explanation??? sorrry if not.
Thanks if you can help me.
Note: i checked on internet, other webs, and google, and found some kind of fix it.
The say need to edit the file Revit.ini in the path: C:\ProgramData\Autodesk\RVT 2025\UserDataCache
but I can not find anything to modify or to change.
Again thanks for any help and solve the problem.
Regards
Victor ROdriguez
- Mute
- Permalink
- Report
I fully understand now - this is controlled by the Revit.ini File and if you delete this it will reset itself. Remember the ProgramData Foler is hidden in Windows 10/11 in File Explorer click on the 3 dots....
This is how the Revit.ini File works and its location
Help | Messages Settings in Revit.ini | Autodesk
Help | About the Revit.ini file | Autodesk
Here is a great link to help you walkthrough how to edit it;
Using Revit.ini to Control and Backup Revit Settings | CADnotes
- Mute
- Permalink
- Report
I will try!!
Thanks, many thanks!!!
Great
also thanks for quickly reply!
Regards
Victor
- Mute
- Permalink
- Report
Hola @rodriguezmarmol,
¡Gracias por participar en la Comunidad Autodesk!
¿Te ha ayudado la respuesta de @jay_colcombe a solucionar tu duda? ¿Lo has podido probar?
Si es así, puedes hacer clic en el botón "Aceptar como solución". De esta manera ayudas a que otras personas usuarias puedan acceder y encontrar más fácilmente la información.
De lo contrario, coméntanos en este mismo hilo para que la comunidad pueda seguir ayudándote.
Gracias y esperamos tu respuesta,
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
- Mute
- Permalink
- Report
Hola @rodriguezmarmol, espero te encuentres muy bien, una vez marcada esta opción ya no te volverá a salir el mensaje, ahora tendrás que renombrar tu nivel en el gráfico y en las propiedades de forma manual:
Digamos que esta opción lo que hace es desligar los dos elementos.
Puedes consultar este artículo en donde describe paso a paso el funcionamiento de este cuadro de diálogo y la posibilidad de reactivarlo con el archivo de inicio de Revit:
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-AB2415E9-FA1A-43F1-820E-D3F7127D30DB
Espero te sea de utilidad, saludos!
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
