robert2JCCH
in reply to: bims2
My apologies for any language barriers.
It sounds like you are attempting to assign a ventilation air per person requirement to an area in the project.
Rooms (found in Architecture tab) do not typically carry this information - Rooms are mainly used for architecture-related parameters
Spaces (found in Analyze tab) can carry this information. The Space Type parameter brings up Space Type settings, which can be defined with a number of values, including ventilation air:
Unfortunately, this would mean having to transfer your UNI sheet values into this Space Type Settings format. This can be done manually, with some third-party addins, and with Dynamo. Once done, you would have this for any future projects as well.
If you still want to use calculated parameters, you should know that you cannot check string text in Revit parameter formulas. So     [if(Parameter="VALUE",A,B)]        is not valid.
