iainsavage
en respuesta a: EDUARDOGONZALEZCBF
@EDUARDOGONZALEZCBF  schrieb:
De acuerdo ahora mi duda es con ese procedimiento no cambia las medidas de la tubería que si quiero se etiquete y aparezca su dimensión en mm? es decir quiero etiquetar tuberias en mm y otras en pulgadas en el mismo archivo y que se vean las dos instalaciones
Ok, now my question is that this procedure does not change the measurements of the pipe that if I want it to be labeled and its dimension in mm appears? that is to say, I want to label pipes in mm and others in inches in the same file and that both installations can be seen
Projects tend to be either metric or imperial so mixing units the way you want is a bit tricky I think.
The only way that I can think of doing it is to create a shared parameter, load it into your tag family and use a formula to convert the value from metric to imperial or vice versa. You would need to load the same shared parameter into your project or template and associate it to the Pipe category.
You could use one tag family with different types and then use visibility parameters to control whether the metric or imperial label is visible, or you could create two separate tag families.
There might be a better way of doing this but that's all that I can suggest.
