247 Views, 2 Replies
11-29-2018
02:57 PM
- Mute
- Permalink
- Report
11-29-2018
02:57 PM
synchronizing tube connections with sandwich plates from Advance Steel to Revit
Hi
Mi name is Felipe and I am working in a project where I need synchronize a steel connection from advance steel to Revit (both 2019 version). The steel connection is of type tube connections with sandwich plates additional objects. I use a base plate for connect the the column and bracing (rectangular profile). The problem is the following. When I synchronize the steel connection from AS to Revit, in the latter only appears the gusset and plates but not the bolts. I have not achieved the reason of this problem. Somebody could help me please?
Thank you!
