696 Vistas, 3 Respuestas
Can we draw angular stock models?
Hi ,
Just a quick question here.
While drawing a stock, is there a way to put an angle on it?
Lets say, instead of the plate being flat is there way to add a 5 degree angle?
brian.dinola
en respuesta a: Anonymous
One approach would be to create a model of the non uniform block using FeatureCam's solid extrude from a curve function or importing a solid model from a 3rd party CAD application and assigning it as a user defined stock solid.
Brian DiNola
Product Specialist Sales Executive
TomOliver
Another way to do this if you don't have solid modeling is to draw a curve inside side of a larger stock and then use stock curve to cut out what you want.
___________________________________________
Inventor Professional
Autocad LT
FeatureCam Ultimate
Fusion 360
Create stl file, import,rotate& then assign as a stock.
