ADVAERO
en respuesta a: ADVAERO
So i just looked up in task manager the program that appears to hang is acewebbrowser.exe located in this directory :C:\Program Files\Common Files\Autodesk Shared\CLM\V3\MSVC11\cliccore\acwebbrowser.exe.
windows task manager lists it as Chromium host executable.
The odd thing is after closing and starting featurecam fresh there pop up  3 instances of acwebbrowser.exe running in the task manager all with different memory usage,they all disappear when featurecam is closed.not sure if this is the problem or merely a symptom of frequent featurecam crashes.
