1027 Vistas, 8 Respuestas
2018 Featurecam crashing often
Is anyone else having trouble with Featurecam 2018 crashing often?  It seems upon opening a file most often.  I had one file open, and opened a second file via File:Open and it hung for a while and then I got the window that said exception error.  I would say I get 3-4 crashes a day.  In 2017, I would have maybe once every week at most.
ADVAERO
en respuesta a: Anonymous
Yes i have been having frequent crashes,i have to save every minute or so so i dont loose any work.There seems to be a common occurance around the crashes they always seem to occur when a featurecam dialog box is open.last time it crashed i looked in task manager and it showed numerous (5-6) instances of something called app chrome (or something to that effect) the was not responding,these all disappeared once featurecam was forcably closed.
now we dont have google chrome web browser (i checked in installed programs) so i can only assume this is part of featurecam.I dont know if this is the cause of featurecam stalling or if it is only a symptom.
**** annoying anyway ,wish there was an Autosave option that i could set.
i should point out featurecam has had a regular crash issue for years now (been using it since 2010),several times a week back when it was a delcam product,but this is way worse and a lot more frequent than ever before.
if the problem is cause its using chrome engine to drive dialog boxs etc then dump chrome its a pile of crap.no one in there right mind uses Chrome.
ADVAERO
en respuesta a: ADVAERO
So i just looked up in task manager the program that appears to hang is acewebbrowser.exe located in this directory :C:\Program Files\Common Files\Autodesk Shared\CLM\V3\MSVC11\cliccore\acwebbrowser.exe.
windows task manager lists it as Chromium host executable.
The odd thing is after closing and starting featurecam fresh there pop up  3 instances of acwebbrowser.exe running in the task manager all with different memory usage,they all disappear when featurecam is closed.not sure if this is the problem or merely a symptom of frequent featurecam crashes.
I was scanning for some info on Featurecam crashes and I came across your post. It has been a while so you may have this already. There is an add in that allows you to autosave. Just go into Manage-Library and load autosave.bas. You can set it to save based on how many features you create or on a time limit. Hope this helps.
Jody
Crashes have sometimes less or not at all. I have been accustomed to saving for several years at regular intervals or after completion of correct operations. Conclusions logically sound. Sincerely, Mathias Beyer
Abstürze habe mal mehr mal weniger bis garnicht. Ich habe mir seit einigen Jahren angewöhnt in regelmäßigen Abständen bzw nach Abschluss von korrekten Operationen zu speichern. Schlussfolgerungen dafür leuchten logischerweise ein. Mit freundlichen Grüßen Mathias Beyer
What else did I notice? Crashes occur most often when I try new things or make many changes or variants of parameter settings teste. Sincerely, Mathias Beyer
Was mir weiterhin aufgefallen ist? Abstürze treten am häufigsten auf, wenn ich Neues ausprobiere bzw viele Änderungen durchführe bzw Varianten von Parameter Einstellungen teste. Mit freundlichen Grüßen Mathias Beyer
rfuentes
sometimes i leave featurecam on the back ground for the longest time and as soon as i switch to the featurecam window it crashes.
bhorstTGM48
en respuesta a: rfuentes
I still am on 2017 R1 SP5 and it never crashes Emoticono muy feliz
I've found a problem with that to that didn't used to be there. when it auto saves it creates a lockfile which prevents it from creating a new folder for your CNC files. It will also create a file with the file name of the part you are working on with a .file extension which also stops yo from saving where you may want to. you must go in through my computer and delete these files to save or create a new file with the part file name.
