- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I understand what you're saying but if I remove all check surfaces, select don't roll over edges, it mangles the part.
See sm2, that is the zlev finish with a single check surface, and don't roll over. (pic 1 is no check surfaces) While it finished the bottom very nicely, the two vertical walls are not finished. It doesn't go out all the way to the edge as it should. It stops like its using the bottom as a boundry.
If a face is selected as a part surface, then why doesn't it cut it? Nothing gets cut if I only choose those two faces and not the bottom.
At this point, all I'm trying to accomplish is to finish those two sides down to the curved bottom, which should take all of about 30 seconds.
Again, sorry, this is so frustrating, trying to use SM'ing to do something and being unable to get there.
