Muppett1
en respuesta a: bmarkeyJ44PH
Please see in message 3 the directive of selecting "don't roll over edges at all" under the "edges tab".  I used this selection in conjunction with selecting 1 check surf to achieve the side milling you see in the last picture.  I understand it will not work b/c of the internal sharp corners, but this does allow toolpath to be applied to each wall surface.
