03-20-2024
04:28 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-20-2024
04:28 PM
Did you import that vise from the addin import vise? If the answer is yes, It should be the sólid as clamp by default and work without any issue.
In any case, try to set up that sólids as clamp by another way, select de sólids but touching the solid/right mousse button/ select the solid/right button again over the selected solid/use solid as a clamp , not in the tree of sólids( in the left side of the screen)
I Hope It works, if not, share the .FM project if you want.
